LabVIEW for LEGO MINDSTORMS and LabVIEW for Education
Labview not working with windows 10
So originally I had labview 15 (32-bit) and 2015 legomindstorms ev3 on my computer which had windows 7 on it. I made the switch the windows 10 and everything seemed fine. But when im in labview and try to target ev3/nxt, labview stops responding and crashes.
(8,766 Views)
Just to mention, Labview itself works fine its just when I decided to target to ev3/nxt is when it all goes haywire
(8,765 Views)
Do you have the mindstorm addon for LV, or are you running the mindstorm reduced LV?
I'd guess the former is more probable to work.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(8,721 Views)
According to prophecy it SHOULd work unless your system is missing some hardware requirements (Screen resolution sounds like a likely candidate)
"Should be" isn't "Is" -Jay
(8,713 Views)
Hi Jeff,
It seems Firefox blocks that link.  Internet Explorer as well.  Both say there is a problem with the site's security certificate.
(8,697 Views)
@RavensFan wrote:
Hi Jeff,
Yeah it is a HTTPS,
I Googled "ev3/nxt" hit the third link
Selected "Support" from the top and then "Software Requirements"  Looking under "Software>>Software Launch Issues" also mentions some MS Silverlight needs.
(8,693 Views)
When you moved to Windows 10, was it through a fresh install or by upgrading through Windows 7? Some issues can come up if you're doing the latter.
(8,644 Views)
