So originally I had labview 15 (32-bit) and 2015 legomindstorms ev3 on my computer which had windows 7 on it. I made the switch the windows 10 and everything seemed fine. But when im in labview and try to target ev3/nxt, labview stops responding and crashes.
Just to mention, Labview itself works fine its just when I decided to target to ev3/nxt is when it all goes haywire
Do you have the mindstorm addon for LV, or are you running the mindstorm reduced LV?
I'd guess the former is more probable to work.
/Y
According to prophecy it SHOULd work unless your system is missing some hardware requirements (Screen resolution sounds like a likely candidate)
Hi Jeff,
It seems Firefox blocks that link. Internet Explorer as well. Both say there is a problem with the site's security certificate.
@RavensFan wrote:
Hi Jeff,
Yeah it is a HTTPS,
I Googled "ev3/nxt" hit the third link
Selected "Support" from the top and then "Software Requirements" Looking under "Software>>Software Launch Issues" also mentions some MS Silverlight needs.
When you moved to Windows 10, was it through a fresh install or by upgrading through Windows 7? Some issues can come up if you're doing the latter.
