wiebe@CARYA
"Static" clone reference
Status: New
This must be duplicate, but can't find it anywhere...
What I'm missing is a Static VI Reference, that instantiates a clone:
It might needs a new name, since it's not a static reference. But "Clone Reference" is ambiguous (a reference to a clone). Maybe "Clone Allocator"?
Obviously, making it a strict type is still possible:
4 Comments
GJMABerends
I would like to see it going even a step further. Like we have a static VI reference and a strictly typed VI reference as you propose only that the strictly typed VI reference inherits all settings from the VI as is set in the properties of the VI not just the reentrant behavior.
nanocyte
It's similar to this idea:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-Asynchronous-Call-By-Reference-with-Strict-Stat...
To get one step closer, with malleable VIs, you can merge the property node and open into one VI. I have this VIM for opening for async
wiebe@CARYA
Knight of NI
This just got better 👍.
To quote LabVIEW 2024 Q1 Features and Changes - NI:
New and Changed Objects
  • The Open VI Reference function includes the following change:
    The vi path input parameter now accepts an existing VI reference in addition to the string and path data types accepted in previous versions. This new option enables workflows such as:
    • Getting a strict reference from a non-strict reference
    • Creating another reentrant instance of a reentrant VI
And it does work:
crossrulz
Knight of NI
Note that as of LabVIEW 2024 Q1, you also need to wire up the type specifier on the Open VI Reference if you need a strict typed VI reference.  For a little more detail: https://forums.ni.com/t5/LabVIEW-Public-Beta-Program-in/New-Open-VI-Reference-Functionality/m-p/4351...
