crossrulz
XOR Array Elements
Status: New
We currently have an AND Array Elements and OR Array Elements.  It would be helpful to also have an XOR Array Elements.  I most often run into needing this when trying to calculate parity.
2 Comments
crazywalt77
Using increment of an integer to measure an XOR for an Array.
wiebe@CARYA
Knight of NI
That doesn't XOR the array, it checks if there's exactly one true value.
The XOR is true if there's an odd number of true's. So in your example, you'd have to use Quotient & Remainder the result with 2, and then do the checks...
This would work though:
