User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
A great time saver would be if we could drag or click to switch connections directly in the connector pane instead of having to disconnect and reconnect controls.
This can be a simple two click process:
If there's already another control\indicator where you click, they get switched.
Available in LabVIEW 2010 and later. Click a terminal in the connector pane, then Ctrl-Click another terminal to swap the controls/indicators wired to those terminals. This technique also works to swap a wired terminal with an empty terminal.
