tst
The ability to move or switch items in the connector pane
Status: Completed
Available in LabVIEW 2010 and later. Click a terminal in the connector pane, then Ctrl-Click another terminal to swap the controls/indicators wired to those terminals. This technique also works to swap a wired terminal with an empty terminal.
A great time saver would be if we could drag or click to switch connections directly in the connector pane instead of having to disconnect and reconnect controls.
This can be a simple two click process:
If there's already another control\indicator where you click, they get switched.
___________________
Try to take over the world!
15 Comments
RayFarmer
Trusted Enthusiast
That is an excellent suggestion.
Regards
Ray Farmer
altenbach
Knight of NI
In addition, we should also have the following shortcut:
<Shift>-clicking a used connector should disconnect it
(faster than right-click...drag down...overshoot...drag up...select "disconnect this terminal"...release mouse...).
GregFreeman
Trusted Enthusiast
One more thing I've noticed. If there is a reason this cannot be done, or in a version later than 8.5.1 it can be done let me know. But it would be nice to be able to select the control then the connector pane. Sometimes I will have the control selected, but have to choose the connector then re-select the control. Again if there is a way around this then disregard this comment 🙂
Message Edited by for(imstuck) on 06-08-2009 04:38 PM
tst
Knight of NI Knight of NI
Knight of NI
You can do this if you explicitly set your tool to the wiring tool, but I never bothered. I agree it's annoying, though.
Since most controls probably don't have a third common action, it would probably be useful if Ctrl could change to the wiring tool, but since I don't use that feature (Shift and Ctrl to get secondary operation) either, I doubt it would be worth it.
A nice compromise might be that if you have a single selected control on the FP and you click on an empty terminal in the connector pane, the control gets associated with that terminal.
___________________
JackDunaway
Trusted Enthusiast
Congratulations on the first ever 100 Kudos'd post! 06 July 2009
muks
Proven Zealot
I am sure this has reached where it was intented to. Nice one!!
Wonger
NI Employee (retired)
This is a great idea, we will be working on this for 2010.
Wonger
Status changed to: In Development
tst
Knight of NI
Thanks.
___________________
Broken_Arrow
I am stoked that this is In Development. Congratulations tst.
Richard
