smercurio_fc, You are absolutely right Sir! I never thought of that, part could be that I was also looking to ignore empty lines. I am sure there could be many other ways to get number of lines, I just posted one of them.
Still learning LabVIEW, haven’t fully come out of dark side.
Another easier way to chop-up each line in an array. Input is an Multi-line string and with a power of for-loop you can set the Count (N) terminal to some high-number which you may never reach. However, the Conditional terminal will stop the loop right after there are not more lines thus you will exit out of the loop soon as numbers of lines have been detected. Cons may be you might an empty element at the end which needs to be removed. That is not hard once you have lines filled in as an elements of an array. Try it see if it you guys like it!!
