Why in the world has no one ever suggested THAT before? In retrospect, that's an obvious, easy, and significant improvement to diagram readability. Gets my kudos!
* Idea if implemented should include the end-of-line and other lone whitespace constants.
One limitation of the feature design I'm proposing (that a UX designer will need to solve), is that it's not obvious to a first time user that these graphical/iconic representations of constant values are actually editable (does it change when you hover? when you click? when you double-click? And, what does it change into?). However, if we extend the idea, as you're suggesting (hey, I see you're a master of the obvious, too!), to all the various useful constants (end of line, whitespace, etc.), then the user will probably learn (reasonably fast) that these iconic nodes are editable.
The mouse cursor change is a good idea for discoverability. Also, if they ever type a space and it turns into the space constant, I think most people would suspect that there's a bidirectional relationship.
crelf: yes. See Kring's picture. But I am not sure how far to run with this idea. I like the idea of double clicking on "Pi" and gettting an expanded 3.141... etc. But I'm uncomfortable with typing in a value and having to match exactly the value of Pi to the nth decimal point used by the constant to have it convert the other way. The idea seems really solid for string constants and not so much for double constants.
There's another vector on this idea... some of the constants in the palettes are just linlined subVIs rather than built-in constants, but to most users, those two implementations are indistinguishable. But if a user writes a VI that has a single output and whose block diagram is a constant wired to that indicator, and it is marked as "inline", then maybe this "double click convert to editable constant" should apply? I think that's too much feature creep, but I'm poking around the edges of the idea to make sure we haven't missed something else obvious.
(Just to remind folks... me getting excited about an idea is no guarantee of it being picked up by R&D, but for ideas like this, I like fleshing them out in the forums since it can make it easier for R&D as a whole to decide to do it.)
I can think of a couple of caveats that need to be considered.
First, when an iconic node is converted to a non-displayable char, such as a carriage return char, a Display Style of Normal for the resulting string constant would be very confusing; but either of Backslash Codes or Hexadecimal would make it quite clear, especially if "Display Style Visible" is also enabled.
Secondly, it will be necessary to pay attention to the platform in the cases of platform-dependent chars, such as the end-of-line constant (\n).
But if these considerations were solved, this could also be educational, AND a way to verify code. When the dev double-clicks on a Carriage Return Constant node, it should turn into an editable string, displayed in 'Hex' Display Style, and 0x0D populating the string. This allows the dev to verify the value before turning it back into a iconic node again.
You can type "pi" in a numeric. It won't accept it, but you can type it.
In a VI, you even get a numeric control's alpha characters from the NumText.text property. So alpha characters in numerics seem to be a pretty well established feature for numeric controls.
This doesn't mean it is easy to implement. It does mean there is a chance that it's easy to implement.
