About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Reversible Merge Errors
I rather often end up in a situation where, if i split an error wire, the split away part is less important, or atleast secondary to the "Main" thread. Thus, when i merge error wires back, i need to wire the broken off part below the Main error, else i can hide or switch error codes, which happens all too easily. It is however a necessary evil right now.
Suggestion: Add a "Reverse error list" to the Merge errors where the bottom one is most important. I guess the merge errors technically does a build array and break at the first error found, so what this'd do is reverse the array.
What'ya think?
/Yamaeda
G# - Award winning reference based OOP for LV, for free! ADDQ VIPM Now on GitHub
"Only dead fish swim downstream" - "My life for Kudos!" - "Dumb people repeat old mistakes - smart ones create new ones."
Certified-LabVIEW-Developer
7 Comments
Do you actually need to reverse the array? Can't you just swap the order of the input wires to the merge error function?
Trusted Enthusiast
Yes, my point is that i wish to avoid that as it causes many wire crossovers. It'd lead to cleaner code.
/Y
Ah ok. I can't support this one. The same argument could be made for all kinds of functions, but I think it would actually make diagrams less clear, not more.
If this doesn't get support, you could always wrap the existing merge errors VI to add the functionality you want.
This has been suggested before here
Tim Elsey
LabVIEW 2010, 2012
Certified LabVIEW Architect
Example Gatekeeper
If I understand you correctly it's because you want to avoid the wire-crossover when doing something like this:?
If that's the case why not just do this:?
Being able to reverse the order on Merge Errors is just one modification. In other use cases you might want an entirely different ordering/prioritization. I'd suggest you place your code in the order that gives the fewest wire crossings. The current LV IDE unfortunately can't help you with this (not even BD cleanup), so it's a manuel hassle :-/ But I'm not in favor of modyfying the prims to reorder their inputs.
Cheers,
Steen
CLA, CTA, CLED & LabVIEW Champion
Bonus info on a slightly different use case; if you want to retain all your errors and warnings, both the most important ones and the less important ones, still within an error wire that isn't an array, you can use the Append Errors function which automatically will sort by priority for when you split the errors and warnings out of the error cluster again - then you don't have any wire-crossings:
Cheers,
Steen
