IMO, the Diagram Disable Structure causes bugs, because the output tunnels of the Diagram Disable Structure are set to "Use Default if Unwired", and the default values are very often not desireable, as can be seen in the screenshot, below:
See this blog article, for more details:
http://thinkinging.com/2008/05/11/the-diagram-disable-structure-causes-bugs/
Re-opening because the implemented feature only made class and reference type tunnels require wiring, and he wants all output tunnels to have "Use Default If Unwired" unchecked.
