| User | Kudos |
| 14 | |
| 13 | |
| 9 | |
| 4 | |
| 3 |
Quite often, in order to locate a particular variable in an array I use the For Loop with Conditional terminal and output the last value of the comparison wired to the conditional terminal to identify whether the value has been found or if we've iterated through the array, without finding the value. - i.e. a really basic example which could probably be done better another way (a better example might be with multiple conditions to satisfy which I quite often have), but hopefully gets the point across:-
It works, but it always looks a bit messy to me, so wondering if there could be an option which would allow you to attach the conditional to the border and allow you to a bit more elegantly pass whether the conditional was triggered out of the for loop.
Dave
