| User | Kudos |
| 2 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
When you create an Installer you need to select what is the other build spec that will be used to be installed.
Some time in the resulting files of an EXE build spec we got files that we don't need to be included in the installer.
So I propose to be able to select only the file that need to be installed, not the entire EXE build spec result.
Currently the EXE build spec result files are grayed out and we can only select the entire EXE build spec result files to be included in the installer.
Any idea that has received less than 6 kudos within 6 years after posting will be automatically declined.
