About LabVIEW Idea Exchange
Have a LabVIEW Idea?
  1. Browse by label or search in the LabVIEW Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  2. If your idea has not been submitted click Post New Idea to submit a product idea to the LabVIEW Idea Exchange. Be sure to submit a separate post for each idea.
  5. Give kudos to other ideas that you would like to see in a future version of LabVIEW!
Format into string with thousands separator
I need a format into string that is capable to format numeric with thousands separators.
Like this  (Visual Aides - Numeric Separators) idea but also for the conversion and scan functions.
Looking at the syntax
%[$][-][+][#][^][0][Width][.Precision || _SignificantDigits][{Unit}][<Embedded information>]Conversion Code
the  <Embedded information>  currently used only for time formats would be ideal to extend to a more general form.
Something like <+ nnn nnn.ddd ddd> would be nice Smiley Happy ( the d is already occupied ... # or whatever .... maybe similar to the excel format syntax or maybe there is a (better) standard??? )
Currently I use the attached vi to add the separators, however it would be nice to have it in a general form
Greetings from Germany
Henrik
LV since v3.1
3 Comments
Knight of NI
Trusted Enthusiast
That's not a duplicate, that idea is even mentioned in this one.
This idea is to extend to scan from and format into functions, while the original only describes control and indicator formatting.
Knight of NI
Hi Wiebe,
You are correct.  I see what you mean.
