fomine
Easy way to copy data from one chart/graph to another
Status: Declined
Any idea that has received less than 7 kudos within 7 years after posting will be automatically declined.
As is, it is very cumbersome to extract data from waveform/graph clusters.
I would love to see it implemented as in Matlab - you select just one plot, and copy - paste it on another graph, or to a waveform/cluster control, or paste as a constant. But mainly, to another waveform chart/ XY graph!
I would see it as right click on the graph-> copy data (as usual) but copy data is not the last thing, it should open up to have:
Copy All
Copy plot 1
Copy plot 2 etc.
And the same, when pasting into a graph,
Paste data ->
Replace data
Append data to the end
Insert data in beginning
Something like this.
Otherwise, now it's a pain if I want to combine two-three xy graphs from 3 different places on one plot!
-fomine
_________________________________
You can do greater things with LabVIEW!
5 Comments
alawsh21
I'm looking for something similar. Does any one knows how to deal with such situation?.
Darren
Proven Zealot
Status changed to: Declined
Alex2019
I am interested to copy data from one graph to another, programmically. I made a sub VI with graph as a control (input) but for some reason when I call this VI from the main program and assign data from existing graph with many plots/data points there are only few points which are transferred to the subVI graph. Any idea why?
wiebe@CARYA
Knight of NI
>Any idea why?
Something must be wrong. Post the question and the VI(s) on the forum, and we can help you.
This is the idea exchange, so you won't get much traction (I won't respond to follow up questions here either).
Alex2019
Dear , thanks for quick response! I solved the problem, beside "value" I use "history data" to make an exact clone of the graph.
