I have a case where a user is supposed to control and run test on a number of connected products (gas analysing probes).
Each product is connected with an RS232 port and also to its own water pump. Before running the tests, the user should assign an RS232 port and a pump ID to each product. When that is done, data like serial number, FW version and status (OK, clogged...) is shown.
A UI good solution would be an array of clusters containing some controls (COM port, pump ID) and indicators (serial number, FW version, status), but this can't be implemented in LabVIEW.
However, each product can preferrably be controlled and monitored with a sub-VI and as all products are identical (except serial numbers and so on), instances of the same VI file can be used (with re-entrant and so on). The front panel of the sub-VI would look something like this:
Now you could show all these front panels as subpanels in the main VI, but the only way to do this in today's LabVIEW seems to be placing as many subpanels you would need on the front panel.
However, this design is really poor as it wouldn't be scalable. The ideal solution would be having an array of subpanels:
Then you could add and remove subpanels/products as you like, and also easily step through them by using a for loop in the code. The thing is that this can't be implemented in today's LabVIEW.
I really encourage NI to implement this feature as it would give a lot of benefits for both the user and the programmer.
I also encourage all the readers to kodus my suggestion.
Declined for reasons listed in AristosQueue's replies.
