Hi
My idea is to connect two nodes without the need to use the mouse to connect the wire. Just select two nodes and use some command(shortcut like (ctrl+n) or Right click and select from drop down)so that, both the nodes maybe connected to each other.
(Note: sorry if this idea already given)
regards
Senthil
Already available with the 'Wire Multiple Objects Together' (Ctrl-W) shortcut with Quick Drop in LabVIEW 2014 and later.
