Labview should have a project setting option to enter command line arguments to simulate what a user could type in at the command line as if they were running the project as an .exe, even though I am debugging from within Labview.
Ultimately, I want to create my project as an executable file. My project would read in the command line parameters as typed in by the user at the command line. Labview already has a property node that reads these parameters. However, that only works when running the project as an executable. I want to debug my project from within Labview.
This would be similar to what VisualStudio has - a project property setting in the project properties. Labview has a project property setting for "Pass command line arguments to application" in the build specifications, but no way to initialize these parameters for debugging purposes.
