You should be able to do that today by creating a polymorphic VI, which is basically a group of VIs, which you drop as a single VI and choose one of them at edit-time. Usually, selecting the relevant VI is done automatically, based on the data types you wire into the VI, but you can also show a selector ring, which would basically function like the enum you want.
That'll actually work well, especially if I name the VIs with the size of their clusters because it'll then give the size of the cluster on the block diagram. And inlining the VIs should remove the calling costs.
I'd like to step back and think about this a different way, especially after seeing that there are two different requests... (1) Show the cluster size visually, and (2) have the number of cluster elements determined dynamically. Right now, I can tell you we will probably never do #2; we want stuff like this statically typed.
But anyway, why do we want to convert between arrays and clusters? I would argue that a common use case is because we are using the array as a sort of polymorphic data type for the cluster. E.g., I used Read Spreadsheet File to get an array of values from a spreadsheet, and I want to initialize a cluster with those values. The array was a convenient data type for reading the data. Do you think this is a common use case for Array to Cluster?
So what could we do to obviate the need for Array to Cluster? (At least most of the time?) Is there something else we should be doing instead?
Also, the cluster coming out is, for lack of a better word, generic. If you are going to convert it to a cluster, wouldn't you rather name the elements? I think someone suggested having a required cluster input for data type (a la Type Cast). Wouldn't this be better than making the number visible?
I use array to cluster only when I need to interface to a dll. For example, say I have cluster, cluster A, that needs to be passed into the dll. If cluster A has a array, adapt to type won't pass in the array in the cluster properly so I create a new cluster B where instead of the array I use array to cluster and replace the array with the cluster so that the array becomes embedded in the top level cluster. This typically comes up when I want to pass text embedded in a cluster (i.e. convert string to array to cluster). In this situation it also works well, that if the string was smaller than the required size, the cluster will always generate the right size.
Here's a little something I discovered as a potentially unsafe workaround. For some context, go see this older posting.
Typecasting an array to a cluster seems to function in a predictable and expected way. The type input of the typecast function then becomes a way to control or document the # of cluster elements.
In my initial app, the clusters in question were typedef'ed. When design changes caused me to add or remove cluster elements, none of the code broke or got buggy like it would have with the "array to cluster" primitive.
Caution: as tst warned in the thread I linked, this may not have guaranteed behavior in future versions of LV.
-Kevin P
ALERT! LabVIEW's subscription-only policy coming to an end (finally!). Permanent license pricing remains WIP. Tread carefully.
I came to post this idea and found this. I really like it, but really I would like to be able to have a cluster input specified. My main reason is that if my cluster is a typedef, if I change the number of elements in the typedef, I don't want to find all of my array to clusters to update the number. I can wrap them in a VI so that I only have to change it in once place, but that feels like a step I shouldn't have to take. The additional input would also get rid of the coercion step when I convert the cluster to the typedefed cluster.
Jeff Peacock
Product Support Engineer | LabVIEW R&D | National Instruments
The cluster size as a numeric input shouldn’t be possible but the size should be somehow visible. I like the idea of a sort of editable label below or above the node that shows the actual size (and possibly could be hidden by the user if he wants to). Maybe mutated code from old versions could start out with this hidden to maintain the look and avoid overlaying other stuff located to close to it.
In addition rather than start out with an arbitrary size when the node is placed on the diagram it should start as adaptable and deduce the size from the downstream cluster size if possible as soon as it gets wired up.
This function existed as far back as LabVIEW 2 and most likely even before and LabVIEW didn’t have backwards datatype propagation back then so it could not be implemented like that. But this node never has seen any love since. That right click option dialog to set the size feels awkwardly out of place nowadays! If anything it should be part of a proper Properties dialog.
I also like the additional option in form of a right click menu option to “Enable Datatype Input” that allows to wire a cluster with the desired cluster configuration. This input wire should be broken if the datatype contains different types of scalar elements or any non-scalar element but the node should allow normal coercion from one numeric datatype to another. So it would properly coerce from an array of integers to a cluster containing floats for instance with the according coercion dot on the input.
Wiring the size as a constant would work, if LabVIEW had something similar to C++'s constant expressions.
A constant expression is a constant that is evaluated at compile time. This would be useful for situations like this (and a few others, like malleable vis). Wiring a control could break the wire, with an error "constant expression required".
I don't see LabVIEW constant expressions coming soon though, but it would be funky.
Wow, it's crazy to see that after all this time we had no solution for this.
I came upon this idea when searching 'how to change cluster size programmatically', I needed to do this for my database connectivity.
This is my solution, it was easy to set-up as in my case the size won't ever be bigger than 30 (I still made a provision for a size up to 100, as it was quick enough to just copy and paste...)
