_carl
Built-in DVR Call Wrapper
Status: New
DVRs are extremely powerful, yet tedious to work with. Much of the coding is just a matter of following the exact same pattern over and over again, while making the code uglier. And I have yet to come up with a good way to reduce that coding overhead...
What if there was a built-in DVR call wrapper that allowed direct access to VIs?
The UI experience could be a hybrid of the Static VI Reference and Call by Reference functions: drop the "DVR Call Wrapper" on the block diagram, drag your VI into it, then wire it up directly.
It could have options for write and read-only.  And it could have right-click options for changing default error behavior.
My standard use case would be class calls specifically, but I don't see a reason this couldn't be applied to any data type -- although some serious thought would have to go into expected behavior in terms of which terminal to treat as the DVR (although this could be dynamic based on which terminal a DVR is wired into, or maybe even settable on the wrapper).
A tool like this would likely save me countless hours of development time, and make it less likely that I'd make coding mistakes while writing routine code.
3 Comments
_carl
Thanks for adding the duplicates -- I've added my votes there. I didn't find those when I searched originally, but I had a suspicion this request had already been made.
It also bothered me that my original screenshot was actually a lazier approach then what I'd really like to have done under the hood in any DVR wrapper.  But...it's such a burden to actually do it this way, that I rarely actually implement DVR code like I'd really want it to be written. Here's what I'd really want to see:
wiebe@CARYA
Knight of NI
No worries, finding ideas is hard. I got lucky.
