There is a bit of inconvenience when I work with typedefs on FP. Very often it is much easier to edit appearance of the control on Front panel:
Make enum width the same as other text fields
Set cluster elements spacing the same as other elements.
Font type and size - apply to all selected, not one by one.
But when control is a typedef, I have to do these changes only in typedef, otherwise they are lost when I change typedef type.
Idea is to add "Apply appearance to typedef" to shortcut menu.
Similar ideas on the same topic (appearance issues when using typedefs)
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/do-not-update-non-strict-typedefs/idi-p/1878823
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Bridging-the-gap-between-strict-and-non-strict-typede...
