ni.com is currently experiencing slowness/issues due to ongoing maintenance.
Support teams are actively working on the soonest resolution.
altenbach
Allow access to default value on control properties dialog
The title says it all: The property dialog of controls should allow inspecting and changing the default value.
Here's how it could look like.
Sometimes I wand to re-define a default value without actually changing the current value.
current steps
  • copy the current value elsewhere
  • enter the desired default value
  • right-click...data operations...make current value default
  • restore the original value (could lose data in case of DBL!)
After implementing the idea
  • right-click...properties...enter default value...OK.
28 Comments
zou
Trusted Enthusiast
Trusted Enthusiast
Array of default values is NI design.
Existed in the VI.
George Zou
RavensFan
Knight of NI
How did you change that property page VI?  It is password protected.
What do you mean
"Array of default values is NI design.
Existed in the VI."  ?
That doesn't sound right.  Show to me that NI has an array of default values and that it is in that VI.
zou
Trusted Enthusiast
Trusted Enthusiast
Just open the VI, maximize the front panel.
If your screen is big enough, you will see 2 numeric array, one for values, one for defaults.
George Zou
Darren
Proven Zealot
Status changed to: In Development
tst
Knight of NI Knight of NI
Knight of NI
Perhaps the change to this dialog is a good time to also implement this other simple idea - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Numeric-control-limits-should-default-to-quot-Coerce-q...
___________________
Try to take over the world!
Darren
Proven Zealot
Status changed to: Completed
Available in LabVIEW NXG 1.0. You can specify the default value for certain front panel controls and indicators in the Configuration Pane.
Christina_R
Status changed to: New
Re-opening because LabVIEW NXG has been discontinued.
Christina Rogers
Principal Product Owner, LabVIEW R&D
Christina_R
Status changed to: Under Consideration
Christina Rogers
