| User | Kudos |
| 1 | |
| 1 | |
| 1 | |
| 1 | |
| 1 |
As the use of touchscreen devices that run full operating systems which support LabVIEW increases, one thing that LabVIEW curiously lacks right now is a replication of the the "Delete" key in either the menus or toolbar. So if someone is working in purely touchscreen mode, it becomes rather obtrusive to simply delete a selection from the Front Panel or Block Diagram.
The only way to delete something would be to bring up an onscreen keyboard, or Edit > Cut. While this is a workaround to this inconvenience, I don't think it's the best solution.
This seems as though it could be a rather quick thing to change, just adding a menu (perhaps under Edit), toolbar, or even an 'eraser' type feature in the Tools pallette item that maps to the same functionality as the delete key.
