As mentioned above, LabVIEW should add an Options>>Block Diagram or Environment setting of "Name Format" for property nodes. Currently you start off with short names (default) or whatever the previous designer of the VI set as the name format of a specific property node. This can lead to confusion if you are used to seeing it one way or the other; and it can be annoying if you want to change the name format of all property nodes in a VI.
LabVIEW should have four options to select as default.
Listed below is an example of the different "Name Format"s of the same property node.
This should be an item in Options as shown below.
