 Jeff_Long
			 on
		06-18-2010
		04:18 PM
			4 Comments (4 New)
			Jeff_Long
			 on
		06-18-2010
		04:18 PM
			4 Comments (4 New)
		The "build text" express VI could be more useful if it included the conversion of Booleans to ON/OFF and YES/NO, and maybe even OPEN/CLOSE in addition to the existing TRUE/FALSE and 1/0 options.
I like the way the Express VI makes my block diagram simple and very readable due the the %parameter name% aliasing format, but having more options would help my VIs to be even better.
For instance, if I'm using a string to transfer a valve state to a valve actuation case in a queued message handler, it would be better to send it as "ValveControl:OPEN" instead of "ValveControl:TRUE" or "ValveControl:1". The former is very clear and the latter two are ambiguous.
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
