cancelar
Mostrando resultados para
Pesquisar então
Você quer dizer:
Ryan_Wright_
Add Delete From String Function to LabVIEW
Status: Already Implemented
As described by raphschru, the Replace Substring function can be used to remove a section of a string based on index and length. Additionally, you can use the Search and Replace String function (with an empty 'replace string') to remove a section of a string based on its value.
If I'm not mistaken, there currently isn't a single function that deletes a certain number of characters from a string. This can be done in a variety of ways using existing string functions, such as the example shown in the picture below. It would be really nice if LabVIEW contained a Delete From String function with offset and length inputs as illustrated in the same picture below. If you didn't wire up the length, maybe it could delete the remainder of the string and maybe an unwired offset could default to 0, similar to the String Subset function.
5 Comentários
crossrulz
Knight of NI
Another option is to use the String To Byte Array (which is a no-op), Delete From Array, and then Byte Array To String (another no-op).
raphschru
Use "Replace Substring" with an unwired or empty replacement string:
Raphaël.
Darren
Proven Zealot
Status alterado para: Already Implemented
Ryan_Wright_
Thanks for the feedback, everyone. I had forgotten about these ways of deleting characters from a string.
wiebe@CARYA
Knight of NI
>@crossrulz:Another option is to use the String To Byte Array (which is a no-op), Delete From Array, and then Byte Array To String (another no-op).
It's not entirely a no-op.
The combination turns a sub array into a normal array, and this could significantly effect performance:
