When you want to "bundle by name" a cluster, you have to connect a cluster input, in order to get all the field available.
This is interresting when you want to modify only some of the elements of a existing cluster.
But when you want to initialize a cluster ... you must connect a cluster constant to the "bundle by name" only to get access to the cluster elements.
It should be nice to have the ability to use a "bundle by name" which could adapt itself from it's output ... when no input type is wired.
Manu.
