User | Kudos |
2 | |
2 | |
2 | |
2 | |
1 |
If the output terminal of "Bundle" or "Bundle By Name" is unwired the vi should should show broken arrow.
You can ask me the question why?
Consider a scenario of the below picture. As soon I wire all the input terminals and input cluster of "Bundle By Name" the vi is in run mode. There is nothing wrong in that, But if I forget to wire the output terminal of bundle by name...... You know what will happen. If it happens in a sub vi of a very big project it is very hard to debug, More over there is no use in any scenario to leave the output of the Bundle By Name unwired,
In the above picture the vi is in run mode when unbundle by name output is unwired
In the above picture the vi shows broken arrow when "bundle by name" output is unwired
