LabVIEW Electrical Power Toolkit
取消
显示结果
搜索替代
您的意思是:
Electrical power toolkit 2021
Hello
I would like to move to labview 2021 but the electrical power toolkit has not been released yet. Is there a workarround to use the 2020 version with labview 2021? Will it be released soon?
0 项奖励
1 条消息(共 4 条)
7,723 次查看
Same issue. I wrote to a couple of NI guys, but no answer.
NI's support on this forum looks quite underwhelming.
0 项奖励
2 条消息(共 4 条)
7,680 次查看
I've had to tinker with this in the past and it is only a set of VIs in vi.lib (and docs, examples etc) so if you really wanted this you can probably copy them from a 2020 installation to 2021 and then mass compile the folders.
I'm not saying I would necessarily recommend it! But if you needed 2021 now then it should work.
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
0 项奖励
3 条消息(共 4 条)
7,675 次查看
Thanks, in the end I did what you suggest James, it was only for evaluating LV2021 for the moment. But on long term I hope to have EPT available officially (or at least a communication of if it will happen)
0 项奖励
4 条消息(共 4 条)
7,671 次查看
