LabVIEW Electrical Power Toolkit
Flicker Measurements
I am trying to calculate short and long term flicker using my VI, image attached.
The values, Pst and Plt, are always zero and I don't know why.
I am reading the data that the scope acquired from a file.  It consists of time and amplitude.
Does anyone see anything, or many things, that I am doing wrong?
Thanks...
(8,356 Views)
The Power Quality measurement VIs do not accept raw data input. You should resample the raw data first.
Please refer to the examples at:
C:\Program Files (x86)\National Instruments\LabVIEW 2017\examples\Electrical Power\Power Quality\Applications (DAQmx)\Flicker Measurement (DAQmx).vi
(8,335 Views)
Is there an example of flicker calculation that does not require DAQmax?.
thanks, Erez
(8,060 Views)
cRIO based example:
X:\Program Files (x86)\National Instruments\LabVIEW 201X\examples\Electrical Power\Power Quality\Applications (cRIO) (Delta-Sigma)
(8,043 Views)
Getting back to the flicker measurement...
I'm trying to calculate the flicker, based on data I measured on a scope.
I can see that to get a valid value, I have to measure at least 10 min and break it to 200msec blocks . Is there a way to use a shorter data (for example, maybe zero padding or pure sinewave padding)?
Also, one of the inputs is the voltage range. There are only 2 options (230 and 120). My system is 400Volt. How should I converter the output?
thanks, Erez
Attached, a picture of the code (I replace the scope data by simulation)
thanks, Erez
(4,386 Views)
