LabVIEW Electrical Power Toolkit
Electrical power toolkit 2021
Hello
I would like to move to labview 2021 but the electrical power toolkit has not been released yet. Is there a workarround to use the 2020 version with labview 2021? Will it be released soon?
(5,929 Views)
Same issue. I wrote to a couple of NI guys, but no answer.
NI's support on this forum looks quite underwhelming.
(5,886 Views)
I've had to tinker with this in the past and it is only a set of VIs in vi.lib (and docs, examples etc) so if you really wanted this you can probably copy them from a 2020 installation to 2021 and then mass compile the folders.
I'm not saying I would necessarily recommend it! But if you needed 2021 now then it should work.
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
(5,881 Views)
Thanks, in the end I did what you suggest James, it was only for evaluating LV2021 for the moment. But on long term I hope to have EPT available officially (or at least a communication of if it will happen)
(5,877 Views)
