11-16-2007 01:45 PM
11-19-2007 10:08 AM
11-19-2007 02:32 PM
Hi Sarah,
Thanks for the response. I reinstalled the visa drivers and still not advanced tab. Please see attached file to see my issue.
Scott
11-20-2007 10:36 AM
11-20-2007 03:19 PM
Hi Sarah,
My PC has card: PCI8331/8336 and the NI PXI-1036 has the following cards installed:
PXI-8331(MXI-4)
PXI-4110
PXI-6221
PXI-2575
PXI-8423
I am having problems with the PXI 8423. As seen in my previous reply, I do not have access to MAX RS485 advanced tab needed to set to "Transceiver Mode".
Scott
11-20-2007 04:13 PM
11-21-2007 08:15 AM
Hi Sarah,
Sorry about the wild goose (or turkey
...) chase. I re-seated the 8331 card in my PC... Problem solved.
Happy Holiday,
-Scott
11-21-2007 08:17 AM
06-21-2012 07:47 PM
Having a similar problem with PXI-8423,
Can't Configure in advanced,
It is only recieving Data, Not Sending.
This card is an older model and has been aroud the office for years.
all 4 ports behave the same.
06-22-2012 11:14 AM
To configure the settings in MAX, you will need to run MAX as Administrator. Just right-click on its icon and select "Run as Administrator."
-Jason Smith
