No advanced tab in NI MAX RS-485 port
Jason,
Thanks for the advice, I will keep thaqt in my armory,
Still wasn't able to transmit though.
iTm - Senior Systems Engineer
uses: LABVIEW 2012 SP1 x86 on Windows 7 x64. cFP, cRIO, PXI-RT
Message 11 of 18
(3,036 Views)
Hi Jason,
What versions of NI-VISA and NI-SERIAL are installed on your machine?  Are you able to change the port configuration in the Windows Device Manager by Properties and selecting Advanced on the Port Settings tab?
Justin D
http://www.ni.com/support/
Message 12 of 18
(3,024 Views)
Justin,
I suspect that your question was directed at me,
When I ran Max as Admin I was able to change the settings (Again, Thanks Jason),
This thread has a couple of handy links that that showed me how to interrogate the port to find out it's mode.
Alas it was 4-Wire, so all configured correctly, But Still No input.
Message 13 of 18
(3,018 Views)
Hi Timmar,
How are you testing the sending and receiving of data with the device?  Are you communicating with another instrument?  Have you tried doing a Serial Loopback Test to verify the operation of the ports?
Justin D
Message 14 of 18
(3,005 Views)
I am testing another device.
I spent the better part of 4 hours testing cabling and hardware and found that when I replaced the 8423 card with a modern 8433/4 It worked fine, This isolated the problem to to card.
The card in question has recently returned from the field after several years without fault but admittedly was only receiving data.
My first response: The port is trashed, alas, all 4 ports behave the same.
As I type, I am wondering if there is a different Pinning or special termination required for the older series cards, My Cables are the RJ50-DB9's that come with the 8433/4.
Message 15 of 18
(3,001 Views)
Hi Timmar,
The port may indeed be bad.  To my knowledge, those cables should not have any issues working with your 8423.
Justin D
Message 16 of 18
(2,998 Views)
I have tested all 4 ports and none of which are working.
I have a crate of dodgey NI Hardware that I will add this card to.
Kind regards,
Tim L.
Message 17 of 18
(2,988 Views)
I have faced a similar issue but I am unable to find the advanced option when I run as administrator and I am also not getting the transceiver mode options in device manager.
Message 18 of 18
(2,001 Views)
