From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
No advanced tab in NI MAX RS-485 port
I installed the NI-Serial Driver, Win XP Service Pack = 2.  Still no luck... no advanced option for NI RS-485 port.  Help, I need the advanced options to set "Transceiver Mode".
Message 1 of 18
(6,734 Views)
Dirtnap,
To be able to see these advanced functions you will need to install the NI-VISA Driver. Please reference the following KnowledgeBase article: Setting the Transceiver Wire Mode on Ports for National Instruments Serial Boards for more information.
Hope this is able to help. Have a great day.
Sarah S.
Applications Engineering
Message 2 of 18
(6,715 Views)
Hi Sarah,
Thanks for the response.  I reinstalled the visa drivers and still not advanced tab.  Please see attached file to see my issue.
Scott
Message 3 of 18
(6,700 Views)
Scott,
What is the specific card that you are currently using?
Please let me know.
Sarah S.
Message 4 of 18
(6,688 Views)
Hi Sarah,
My PC has card: PCI8331/8336 and the NI PXI-1036 has the following cards installed:
PXI-8331(MXI-4)
PXI-4110
PXI-6221
PXI-2575
PXI-8423
I am having problems with the PXI 8423.  As seen in my previous reply, I do not have access to MAX RS485 advanced tab needed to set to "Transceiver Mode".
Scott
Message 5 of 18
(6,677 Views)
Scott,
An alternate way is to set this option in Device Manager. If you right click on the NI PXI-8423/2 Port, you are able to move the proper tab. I have attached a picture of the exact place to look.
Please let me know if you were able to find this on your system.
Sarah S.
Message 6 of 18
(6,671 Views)
Hi Sarah,
Sorry about the wild goose (or turkey Smiley Wink...) chase.  I re-seated the 8331 card in my PC... Problem solved.
Happy Holiday,
-Scott
Message 7 of 18
(6,660 Views)
Hey Scott,
Glad it is resolve! Have a great holiday!
Sarah S.
Message 8 of 18
(6,655 Views)
Having a similar problem with PXI-8423,
Can't Configure in advanced,
It is only recieving Data, Not Sending.
This card is an older model and has been aroud the office for years.
all 4 ports behave the same.
iTm - Senior Systems Engineer
uses: LABVIEW 2012 SP1 x86 on Windows 7 x64. cFP, cRIO, PXI-RT
Message 9 of 18
(5,824 Views)
To configure the settings in MAX, you will need to run MAX as Administrator. Just right-click on its icon and select "Run as Administrator."
-Jason Smith
Message 10 of 18
(5,817 Views)
