取消
显示结果
搜索替代
您的意思是:
Connect to climate/temperature chamber in LabVIEW
I'm sort of new to LabVIEW/a student and during my internship at a company I got an assignment to develop a remote control interface for the Weiss WT3 climate chamber for their tests. I'm using LabVIEW 2014 64-bit.
My previous experience in LabVIEW has been using the NI USB-6211 for remote controlling power supplies with analog voltage control and that is a bit more straight forward, I think.
Anyone with experience in this area that has any VIs that I can take a look at?
Here are some of the things I'm unsure of
  • How to connect it physically? There are Ethernet, USB and RS232 connectors as far as I can see
  • Use the bundled software with LabVIEW or only use LabVIEW?
0 项奖励
1 条消息(共 17 条)
11,789 次查看
You would use whatever physical connection you want/that the chamber supports. A brief look at their web site says rs-232 is standard with other others as options.
Your second question does not make much sense to me.
If you have the manual, please attach it. I don't see it on their web site for download.
0 项奖励
2 条消息(共 17 条)
11,769 次查看
Thanks for the reply.
Sorry if the question doesn't make sense. I'm trying to articulate myself as best as I can (english is not my native language).
What I meant was that the oven comes with some software bundled with it to control the chamber via Ethernet, and I was thinking whether or not I am supposed to make LabVIEW communicate with that software (internally on the PC) or I should focus on somehow communicating with the chamber directly from LabVIEW.
I have succesfully used the application for remote controlling the chamber (although it does its job poorly, and has a lot of problems)
Unfortunately I'm not certain the manual is even available as a digital version anywhere. I know I've search a lot on the Internet for it, but without results. I only have a hard copy in the lab.
0 项奖励
3 条消息(共 17 条)
11,747 次查看
Controlling an exe can be difficult unless it has a published interface such as ActiveX. Since it doesn't do what you want, controlling the chamber directly from LabVIEW sounds like a better option. There are TCP/IP functions that you can use. This all assumes that the protocol for reading/writing is documented on the manual.
0 项奖励
4 条消息(共 17 条)
11,733 次查看
If you are looking for a pdf version of the protocol for rs232, please find the attached.
I can comminicate with the device(wt180/40) from labview. I am using rs232 interface to communicate to the device.
0 项奖励
5 条消息(共 17 条)
11,624 次查看
sorry. forgot to attach the file. 😛
6 条消息(共 17 条)
11,622 次查看
Since you say that can communicate, your problems are solved?
0 项奖励
7 条消息(共 17 条)
11,610 次查看
I am looking for the same solution you can help me if you have found the solution
0 项奖励
8 条消息(共 17 条)
7,695 次查看
I'm looking for Weiss Chamber SB2/1000/40  LabView driver too
0 项奖励
9 条消息(共 17 条)
6,584 次查看
Hi
Did you contact Weiss already?
greetings from the Netherlands
0 项奖励
10 条消息(共 17 条)
6,549 次查看
