02-01-2021 03:44 PM
Yes I have contacted the local agent for Weiss in Australia and LabVIEW drivers do not exist. They want you to buy their Simpati software to control the oven instead.
Seems like I have a coding challenge ahead of me!
04-26-2023 03:31 AM
Did you get any luck on creating a LabVIEW driver/code to control the climate chamber?
04-26-2023 05:21 AM
04-28-2023 02:45 AM
It is the same manual.
Firstly I'm a bit confused on what commands you can sent to it. I've tried connecting via NI MAX and did a visa test Panel in hopes of sending a command and checking the visa connection that way. But so far I have not been able to get a respone form the climate champer sending. I have tried sending both "{STX}z?E8{ETX}" as well as "$01I<CR>" but I keep getting timeout errors as there are no respons.
04-28-2023 06:21 AM
Maybe you can send an example vi with the string you asked and all the settings of the serial port?
It could be that the system requires a bit more coding, better initialization, or better hardware wiring.
I can look at all three but not without more information from your side.
12-14-2023 03:41 AM
It's just to share my experience (that's why I don't open a new topic), as I also had to control a Weiss Climatic Chamber (using an Ethernet connection in my case).
I installed the Simpati software (evaluation only - V4.80), and after I configured the communication with the climatic chamber, I now only use a TCP/IP communication with the Simpati server to control the climatic chamber (you can find the protocol definition in the documentation installed with Simpati).
I can not garantee it, but it seems that there is no license needed for this part. I just prepared a script to launch SimCreate.exe, SimC3k.exe (depends on your model I suppose), then SimServ.exe -P7777 -start when the computer starts (note: I added some tempo between each command line).
For the LaVIEW code, you can use this snippet for test
or just open a TCP/IP communication on localhost, port 7777.
Communication frame examples for climatic chamber #1 (\ notation) :
Set regulation ON : 14001\B61\B61\B6true\r\n
Set Treg=20.5°C : 11001\B61\B61\B620.5000\r\n
Set Hreg=50% : 11001\B61\B62\B650\r\n
Hope that it will be useful for others
Adeline.
02-16-2024 08:28 AM
Hi! I got the same issue right now. Did you find any solution?
