01-28-2008 08:11 AM
Warp,
This board is for discussions of the NI digital I/O devices. You would be better off posting to the Multisim board.
02-12-2008 11:51 PM
02-15-2008 01:24 PM
Good luck with your application and sorry that I can't help you more!
02-15-2008 01:24 PM
02-15-2008 01:47 PM
Like Elizabeth said a new thread would be better. Now you have to do with my answer
Can you order components at Farnell ? They have the diode you want.
Another option is the SB3H90 from VISHAY (90V - 3A)
02-16-2008 11:01 AM
11-18-2008 09:21 AM
We're using the USB-6501 (works with USB-6008 too) directly connected to the Solid State Relay.
Pin 2 (+5v) and pin 16 (port 2.0) is connected to the relay directly. Internally pin 16 is connected to pin 2 through 4.7k resistor.
When you power up the module the relay is inactive (both pin 2 and 16 actually going to the same +5V on the USB module).
Later the software creates a digital out channel and when you activate it pin 16 is sent to GND (ground) and the relay gets the required power.
11-28-2008 07:14 AM
Hi Sandesh,
The module you are looking for is available from www.msr-elektronik.com
This module is called HM 1 - 5
See also: http://www.atrie.de/Produkte/Katalog/hm1-hm2.pdf
_______________________________________________________________
More information on Industrial Automatiom can be found at:
http://www.industrial-automation-hands-on.com/
