Digital I/O
Conver TTL into Relay
I am using USB 6501. I wish to convert TTL signal into 8 nos. Relay output. The Relay I using is % V Dc Omron Relay with 40mA Current capacity.
Pl advice to use current booster and how to put into Circuit?
Regards
Sandesh
Message 1 of 38
(18,055 Views)
Hi Sandesh,
A simple relay driver.
Message Edited by K C on 10-26-2007 08:55 AM
Message 2 of 38
(18,042 Views)
Hey KC!
Sincere Thanks for posting this driver circuit. Firsr can you tell me whether such Driver Circuits is available readily in Market?
Secondly Pl. intimate the Transistor no. and I trust you have mentioned 2K resistor across the TTL and 0V.
Pl. confirm.
Regards
Sandesh
Message 3 of 38
(18,035 Views)
I am sure that these devices are on the market, but you have to look for yourself.
The transistor is a standard NPN. a 2N2222A will do.
Message 4 of 38
(18,030 Views)
Dear KC,
Do you know any IC which can give 8 drivers.
And may ask your base country?
Regards
Sandesh
Message 5 of 38
(18,028 Views)
Something like ULN2001, but if your are not that familiar with electronics should you even try it ?  Smiley Surprised
I am living in The Netherlands
Message 6 of 38
(18,024 Views)
Dear KC,
If you tell me the input and out put conncetion leads then I can use IC.
IC datasheet is available on RS site.
Regards
Sandesh
Message 7 of 38
(18,023 Views)
Something like a ULN2001.... you should use a ULN2003 for your circuit.
Here it is for 1 relay.
Message Edited by K C on 10-26-2007 04:23 PM
Message 8 of 38
(18,014 Views)
This is great. This circuit will give 7 nos. output. Is there any IC which will give 8 nos. output?
I am going out of station and hence may not able to reply for 5 days.
Regards
Sandesh
Message 9 of 38
(17,998 Views)
Try ULN2803A
Message Edited by K C on 10-29-2007 09:26 AM
Message 10 of 38
(17,975 Views)
