BreakPoint
fizbuzz - a simple coding challenge
Did all this somehow turn into a Rube Goldberg competition? 😄
Message 31 of 41
(10,466 Views)
For me: yes 🙂
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 32 of 41
(10,455 Views)
jcarmody wrote:
@Henrik Volkers wrote:
How about a one line regular expression someone?
Hmmm...
I don't know if it's possible with one line, but I had to try this puzzle using regex,
"I won't be wronged. I won't be insulted. I won't be laid a-hand on. I don't do these things to other people, and I require the same from them." John Bernard Books
Message 33 of 41
(10,410 Views)
Here's two ideas for a Rube Goldberg version of fizzbuzz... 😄
1) A VI that, for every integer n, run queries on Wolfram Alpha to check whether n is divisible by 3 and 5. Use the true or false responses to build your list of fizzes and buzzes. Remember to put in a nice long delay in your loop to avoid being blacklisted for denial of service...
2) Add the digits of the integer n together, and check whether the sum is divisible by three. Check the last digit to see whether it's 0 or 5, and proceed. You could be lazy and use Q&R to check the divisibility of the sum, but why stop there? This is supposed to be a Rube, goddamnit!
Actually, thinking about it, using the second allows you to test huge numbers:
CLA
Message 34 of 41
(10,395 Views)
Fizzbuzz mentioned on Codeless Code, here - http://thecodelesscode.com/case/187
Jim
Message 35 of 41
(9,666 Views)
Pardon the ressurection, but I just read this thread and had to claim the least number of functions. Would have been less if I didn't have to stop at 100.
Josh
Software is never really finished, it's just an acceptable level of broken
Message 36 of 41
(9,413 Views)
Resurrecting the thread after exactly six years with a Python/regex solution:
import re
for i in range(1,101):
    out = ''
    if(re.search('^(0|1(01*0)*1)*$', bin(i)[2:])): out = 'FIZZ'
    if(re.search('[0-9]?[05]$', str(i))) : out += 'BUZZ'
    if(out == ''): out = str(i)
    print(out)
Jim
Message 37 of 41
(6,123 Views)
import re
    out = ''
    print(out)
That source is flawed 😋.
Requirements clearly state to output "Fizz", "Buzz" and "FizzBuzz". Not "FIZZ", "BUZZ" and "FIZZBUZZ":
Write a program that prints the numbers from 1 to 100. But for multiples of three print "Fizz" instead of the number and for the multiples of five print "Buzz". For numbers which are multiples of both three and five print "FizzBuzz".
Message 38 of 41
(6,100 Views)
I do love my selects (a back to the basics code)
Message 39 of 41
(6,048 Views)
So basically this ancient thread went full circle, because that's what started it all. Except that you now do a lot of string manipulations that you throw away in most cases a nanosecond later. So why do them unless needed? Also note that there is an "empty string?" primitive.
Compare that to the simplicity of e.g. my version.
Message 40 of 41
(6,038 Views)
