BreakPoint
fizbuzz - a simple coding challenge
I read today's Coding Horror blog titled "How to Hire a Programmer", then followed a link to another titled "Why Can't Programmers... Program?"  It was in the second one that I read "[...] 199 out of 200 applicants for every programming job can't write code at all. I repeat: they can't write any code whatsoever."  The author meant that quite literally.  He then suggested a simple coding test to weed out the non-programmers:
Write a program that prints the numbers from 1 to 100. But for multiples of three print "Fizz" instead of the number and for the multiples of five print "Buzz". For numbers which are multiples of both three and five print "FizzBuzz".
The comment that got me to write a solution was "Most good programmers should be able to write out on paper a program which does this in a under a couple of minutes."  Could I write this in just a minute or two (or three)?  I wasn't too surprised that I could, and I expect that many of y'all can, too.
This would be a good test for folks that are just beginning (students, I'm talking to you).  Perhaps you've passed the CLAD (or CLD) and are feeling pretty good about yourself.  Try it, you may like it.
Jim
Message 1 of 41
(24,953 Views)
A nice task I hope I solved without any Rube Goldberg codeSmiley Happy
Even
_________________________________
Certified LabVIEW Associate Developer
Automated Test Developer
Topro AS
Norway
Message 2 of 41
(24,941 Views)
Mine was similar:
Spoiler
Jim
Message 3 of 41
(24,933 Views)
Spoiler
Greetings from Germany
Henrik
LV since v3.1
Message 4 of 41
(24,928 Views)
Henrik,
This is not a code obfuscation contest!  😄
Jim
Message 5 of 41
(24,922 Views)
I haven't tested it for speed, however I wanted to avoid two quotient&remainder vis  😄
How about a one line regular expression someone?
Henrik
LV since v3.1
Message 6 of 41
(24,915 Views)
Mine's v.similar to jcarmody's, but slightly more convoluted thanks to the select VIs Smiley Sad
Spoiler
"If anyone needs me, I'll be in the Angry Dome!"
Message 7 of 41
(24,914 Views)
I was referring to your first solution.
Hmmm...
Jim
Message 8 of 41
(24,911 Views)
Don't be :(.  You just beat 199 out of 200 people applying for a programming job.  🙂
Jim
Message 9 of 41
(24,911 Views)
Still small thing you have that kind. You could have used Equal2Zero.png instead of Equal2Zero - 1.png. Smiley Wink
Message 10 of 41
(24,909 Views)
