BreakPoint
This is Hooovahh
Wire color in test stand
I was contracted out to do the software on a test system, where another company was doing the hardware.  They purchased the hardware, built the stand, wired up the system and then had me come in and deploy the software.  The system had several NI DAQ cards and they broke out to SCB-68 terminal blocks that all the IO was then wired to.  I started debugging my software and I wasn’t seeing the signal values that I expected.  So I opened up the stand and started tracing the wires to see if it was wired right.  When I opened the test stand I saw lots of red wires, I mean lots and lots of wires with red insulation on it.  So I opened up one of the SCB and...no labels on any of the wires.  The SCB had probably 2 black wires (also not labeled) and probably another 50 or so red wires.
The engineer that wired up the test system was standing by and made the comment:
“There is a color code to help you.  If the wire is black, it is a ground.  If the wire is red, it might be a ground.  I started with black wire and ran out and had to use red for ground in a few places.”
Tracing wires, and using a meter to find where the wires go was a bit of a pain.  I'm pretty sure that was the last test system he made.
Message 261 of 520
(10,348 Views)
That's a lot of 5V power lines. (ATX Standard).
I once heard of a test system at a company I used to work at where the technician wired a power line through a fan grating.  There were a lot more "issues" with that system, but that is the one I especially remember.  Needless to say, the customer was furious and a different technician was sent to fix it.  The new technician pretty much ripped everything out and completely rewired it.  Supposedly, the customer made a plaque stating to never buy a test system from that company again.  Luckily for me, I got to install new racks about a decade later as a fresh graduate.  I put in a good year cleaning up that system as much as possible, from spinning the interface board to major cleanup of the C++ code.  The other system I did at the same time was a complete redesign, including using LabVIEW instead of Borland C++.
GCentral
Message 262 of 520
(10,340 Views)
Poor guy, he probably should have had more oversight from someone else at the company...
"I would have opened a new spool of black wire, but I heard there is a highlight execution feature so you can see what data is on each wire" 😄
Message 263 of 520
(10,320 Views)
The United States Navy did not allow personnel with Red-Green color blindness to train as an Electronics Technician.
If I say, "Keep your stick on the ice!" Will I get a lifetime supply of kudos or duct tape?
"Should be" isn't "Is" -Jay
Message 264 of 520
(10,309 Views)
Alas, I can only give 1 kudo...
GCentral
Message 265 of 520
(10,296 Views)
Oh no! Can A lifetime supply of duct tape  be forthcoming?
Thankfully, I do not believe that my current postal address is public knowledge. 😉
Message 266 of 520
(10,288 Views)
Oh that reminds me that my electronics professor was color blind and had a hard time reading the various color codes resistors.  He could do most of them but every once in a while he would have to ask what the colors were.
Message 267 of 520
(10,270 Views)
There's an app for that nowadays. Several actually. Haven't tried any of them.
Message 268 of 520
(10,264 Views)
Not when you can't see the difference between 2 and 6
Message 269 of 520
(10,254 Views)
This makes me curious - I know there are apps that interpret the resistor color code for you, but has anyone come across an app that actually does the "looking" for you? That uses a built-in camera to "see" the colors and interpret the resistor value?
-joeorbob
Message 270 of 520
(10,242 Views)
