BreakPoint
Rube Goldberg Code
@Steve Chandler wrote:
This construct is very similar to the first reply in this thread. Maybe the following code was posted in one of the other many replies.
Found in a code review.
There's too much confusion
can't get no relief
Buisness men they drink my wine
Plowmen dig my earth
None would ever compromise
Nobody of this world
Smiley Very Happy
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
Message 981 of 2,635
(12,205 Views)
Plot Images.vi found with the example finder is not exactly an RG but there is some pointless code.
Spoiler
I am guessing this was originally written before LabVIEW had the event structure and #3 was overlooked.
LabVIEW 2012
Message 982 of 2,635
(12,178 Views)
A simple array transformation apparently needs a lot of code (top). The bottom shows an equivalent alternative, too simple! 😄
Note that LabVIEW is actually smart enough to fold most of the while loop code ("transpose", "array size", "index array", "-1"), because it is loop invariant. WIthout this feature, we would repeat e.g. the same transposition on the same data N times in a row.
(seen here)
Message 983 of 2,635
(12,115 Views)
Found in Agilent 34790.Lvlib:List to array
Spoiler
(c) 2005-2010 National Instruments.  ALL RIGHTS RESERVED.
 for whatever its worth I think the string searches in the upper case call the split string function anyway but I won't bother benchmarking either
"Should be" isn't "Is" -Jay
Message 984 of 2,635
(12,074 Views)
That "continue if true" is a hint that this is ancient...
Message 985 of 2,635
(12,067 Views)
Just when you thought you've seen it all, a VI gets posted that pushes the boundaries a little bit more.
Just look at the navigation window. It actually brings LabVIEW to its knees. redrawing the navigation window is really sluggish on my machine. 😄
(seen here. Also notice that some people program the same way as they compose post titles ;))
Message 986 of 2,635
(12,002 Views)
The curious case of the blue booleans!
Is there a reason to temporarily convert booleans to numbers just do do some boolean operations?
(seen here)
(Of course we would also have e.g. "in range and coerce" to simplify things even more ;))
Message 987 of 2,635
(11,929 Views)
To do it just like it was developed in VB.  (If I remember my text programming correctly)
Message 988 of 2,635
(11,922 Views)
Really this thread is very good and very much useful.. My hartley thanks to the author.
Silver_Shaper | CLD
Message 989 of 2,635
(11,845 Views)
(seen here)
I've been digging through code tha looks like this for the past month..
Except for the locals..
Message 990 of 2,635
(11,772 Views)
