BreakPoint
Rube Goldberg Code
I have the gut feeling that this can be simplified significantly 😄
(seen here)
Message 991 of 2,635
(12,240 Views)
I may as well start posting the Rubes that I've been fixing along the way.  Imagine spending each day for the past month fixing Rubes and other non-sense.  I'm at the point where I think the enhanced code has Rubes of its own... 😛
This one concatenates the bits to create a word which is written to a register.  Hundreds of variations of this one.  There's a few which had these values concatenated to each other by passing the value (output) to param1.  Imagine this sub-vi creating a 16-bit word where is concatenates 2 bits at a time!
The top right solution circled in red replaced the rest of the code.
Message 992 of 2,635
(12,171 Views)
The funny part is that this one is a sub vi where the person goes to the trouble of selecting 1 out of 4 constant strings and converts it into 4 ASCII parts only to recombine into a U8 array.
There's an app for that..  It's called "String to Byte Array".
Code is full of things like this.  I could spend my days posting RG's...  Even retire by doing so..  but I'm sure there's better things to do upon retirement than posting RG's.  😉
Message 993 of 2,635
(12,162 Views)
Well, the lower part might be 4x faster on a quad CPU, because all four conversions can execute in parallel. 😄 (Just kidding!)
Message 994 of 2,635
(12,153 Views)
I can imagine that one didn't notice that there was allready something for that...
What I don't understand is why people don't make a vi when they create the same code multiple times.  I allready do that when I would use code twice!
Message 995 of 2,635
(12,145 Views)
I don't get the thing with the array at all. It could be something left over from a code-n-fix spree.
LabVIEW 2012
Message 996 of 2,635
(12,069 Views)
I do that sometimes, to make the wire thicker so it can carry more current. You normally see this on longer wire lengths than the one shown. Highy recommnded for the green wires (ground).
Richard
Message 997 of 2,635
(12,063 Views)
But don't you run the risk of creating ground loops?
Message 998 of 2,635
(12,050 Views)
Did you even bother to read the manual? Ground Loops are the loops placed toward the bottom of the wiring diagram.
For my next Micro-Nugget, I'll be discussing using multiple Not gates in parallel to boost power in Boolean wires.
Richard
Message 999 of 2,635
(12,045 Views)
To take the average for each column of a 2D array apparently needs a huge scaffold of arrays and complicated integer operations that always result in a plain zero (Top of image). A possible code alternative is shown below it.
(seen here
Message 1000 of 2,635
(12,037 Views)
