BreakPoint
Rube Goldberg Code
you forgot simply using an inverter.......
...... NOT!
Message 51 of 2,641
(30,706 Views)
Hmmmm....
So if the value is zero, we need a one and if the value is nonzero, we need to add one to the value. This is complicated.
What would happen if we just blindly add one in all cases??? 😮
Message Edited by altenbach on 05-11-2007 09:05 AM
Message 52 of 2,641
(30,646 Views)
Lol, well, I just discovered this thread, and I remembered a recent posting in which I drawed some Rube Goldberg Code, so I came to share it with you, but seems altenbach did it first Smiley Very Happy  (The code in the Plus One? entry is mine). Well it's a bit embarrasing to find it out, but...what can I say? I posted it...Smiley Sad
To my defense, I was sleepy and had no cofee near.
P.S. This thread is really fun, I'm having a great time here...shame I'm a contributor.
Message Edited by Robst on 05-15-2007 05:09 PM
Robst - CLD
Using LabVIEW since version 7.0
Message 53 of 2,641
(30,603 Views)
No, you should be proud! Welcome to the club!
Any LabVIEW programmer who claims he has never made any RG code is a liar! 🙂
Besides for the comic effect, this thread actually is a great learning tool for many. Don't underestimate its power.
Message Edited by altenbach on 05-15-2007 04:45 PM
Message 54 of 2,641
(30,593 Views)
Hey, thanks for the welcome altenbach!, now I feel much better Smiley Very Happy
And yes, I agree with you, this thread can be a great learning tool for many. Some common mistakes are shown here, so others can learn a better way to get the same results....actually I've learned some things.
Regards!
Robst - CLD
Message 55 of 2,641
(30,570 Views)
Say we need to process an array of clusters and format it into a table where each cluster forms one line and then write it to a text file.
We could do it with three frames of a stacked sequence, using a While loop where we need to keep track of the array indexing, array size, unbundling, parsing all parts individually, and concatenating all fragments to the previous line by bouncing it trough a local variable of and indicator that we really wouldn't even need otherwise....
Notice that we measure the array size at every iteration of the loop. Since we read the local at every iteration we are not sure if other parts of the program will change it 😮
Or we could just use a small autoindexing FOR loop to do basically the same. 🙂
Do whatever is more conveninent! 😄
(Of course there are quite a few othere ways to do this.)
Message Edited by altenbach on 05-24-2007 08:30 AM
Message 56 of 2,641
(30,506 Views)
We have an existing 2D array and need to initiaize an array with the same size, containing all zeroes.
We can do it the hard way or the easy way.
The easy way also has additional advantages, for example LabVIEW can potentially re-use the existing buffer and do things in-place..
Message Edited by altenbach on 05-28-2007 11:01 AM
Message 57 of 2,641
(30,471 Views)
...but what if you wanted to re-use the buffer in another part of the code? Since the array size can be scheduled to run before the other code, it only has to look a the buffer before it is uesd elsewhere.
Now I have not checked recently but in LV 5 or there-abouts, the top input of the math operators was re-used...
Ben
Message 58 of 2,641
(30,446 Views)
Ben,
Would you not simply bring a wire to the other part of the code? or better yet, use a Functional Global Variable to avoid messy wires on the block diagram?
RayR
Message 59 of 2,641
(30,442 Views)
For those that have not seen the discussion see this thread on LAVA were Rolf and I agreed there was something wrong with memory allocation.
And yes Ray, an Action Engine is the easiet way (that I know of) to manage my memory usage.
Ben
Message 60 of 2,641
(30,432 Views)
