BreakPoint
Rube Goldberg Code
@altenbach wrote:
@Yamaeda wrote:
If you add a U8 to a I32, to you explicitly convert the U8 first? 😉 I mean, the code is more correct, but the extra blocks makes it a little harder to read, since i always think "why are they doing this explicit conversion?".
In addition, an explicit conversion is sometimes more expensive. (Example, but you would think the compiler should create identical code. I have not tested in recent version) 
Debug still turned on? My impression was that the explicit conversion was making more places that could be probed, etc. With debugging off, I would expect identical code.
Message 2631 of 2,639
(1,153 Views)
In principle, there is still an extra memory allocation of the lower DBL array while the multiplication might know how to multiply an integer with a DBL directly. No time for extensive tests at the moment ....
Message 2632 of 2,639
(1,139 Views)
Yeah i remember that little nugget. I assume it allocates a new array or something. Maybe Bool to number should have configurable output like the Multiply has?
Qestit Systems
Certified-LabVIEW-Developer
Message 2633 of 2,639
(1,068 Views)
exactly 😄
Message 2634 of 2,639
(1,058 Views)
@altenbach wrote:
exactly 😄
It was only suggested in 2009, give'em some time! 😉
Qestit Systems
Message 2635 of 2,639
(981 Views)
I have no intention debugging this mess, but here's a small section that I think tries to do a rolling average.
(so what's wrong with the ptbypt version???)
Message 2636 of 2,639
(301 Views)
The original programmer didn't see it on the pallets, didn't recognize what it does?
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 2637 of 2,639
(219 Views)
I'm sure I have made something like this with shift registers, when I was using LV 5.0 and was new to LabVIEW.
Certified LabVIEW Architect
Message 2638 of 2,639
(191 Views)
Yes, with shift registers, one would be enough because you can expand the left side for even older data. I think there were even ancient NI examples that showed that.
The problem is scalability. Once you want to do a 100 point average only a scalable solution is doable. (Here's an efficient but simplified example  that can average multiple channels simultaneously, something the stock ptbypt cannot do.)
Note that feedback nodes allow selection of the history, so the above mess could have used a pattern as follows, eliminating a lot of backwards wires.
But as discussed, this is still never the way to do it....
Message 2639 of 2,639
(78 Views)
