BreakPoint
Rube Goldberg Code
@Ben wrote:
Type cast
I was just starting some ....and poof .John Crapper shows up
For those of you Googling now, mr. Crapper invented the flush toilet.
"Should be" isn't "Is" -Jay
Message 2271 of 2,635
(9,793 Views)
Can anyone guess what's in the TRUE case??? (Same, just with a FALSE diagram constant!)
Message 2272 of 2,635
(9,720 Views)
Getting the bits from an integer seems to require a lot of code. I am sure there is a one-liner solution 😄
(seen here)
Message 2273 of 2,635
(9,673 Views)
Not quite a one liner but one Boolean AND per boolean output would work perfectly. Alternatively you could convert it in an array of booleans and then use Index Array, but I'm not so fond of that solution as it is damn easy to mix up the indices, kind of difficult to verify (counting Index Array terminals and translating them to bit position and back is always a chore, error prone and needs to be done every time again when you want to debug and verify the code) and not really less work. The solution with translating it then to a cluster as suggested by cbutcher avoids some of those problems but only if you don't have to many "holes" in the booleans.
And if I program for FPGA, the Boolean AND is definitely THE solution. Anything else will tend to use more resources.
Rolf Kalbermatter  My Blog
Message 2274 of 2,635
(9,625 Views)
Perhaps to Bool Arr and then Array to Cluster with the appropriately ordered fields?
Renumber cluster elements neatly shows their indices.
In this case you'd need a couple of dummy elements for the unused bits, but perhaps still a reasonable solution?
GCentral
Message 2275 of 2,635
(9,620 Views)
Yes, that was my one-liner idea. I actually made a draft yesterday but did not post it.
Message 2276 of 2,635
(9,604 Views)
Hmm, how do I get the array size. Like this I guess:
Certified LabVIEW Architect
Message 2277 of 2,635
(9,482 Views)
And, how to get the maximum value of an array:
Message 2278 of 2,635
(9,475 Views)
The for loop is ridiculous of course.
The array to cluster + unbundle has the advantage of being 'vertically friendly'.
It might grow on me 😊.
(Note that I do not need this a lot)
Message 2279 of 2,635
(9,460 Views)
Bah!  If that's what you're going for, don't RG it. Just make a malliable VI 🙂
Message 2280 of 2,635
(9,424 Views)
