BreakPoint
Monthly Bugs, September 2010
Add XControl Properties creates the folder but without any template vi's
Message 11 of 27
(12,935 Views)
Link? CAR?
Message 12 of 27
(12,928 Views)
Message 14 of 27
(12,919 Views)
Details
BSOD with USB-6211
Message 17 of 27
(12,806 Views)
Message 18 of 27
(12,805 Views)
Distributed System Manager has numerous bugs:
1. Save Workspace does not work correctly, position and graph size information is totally lost when saving.  Also the act of saving will reset size and position of many panels.
2. Data field in the plot legend of a historical chart does not update correctly, many times it will show (no data) when I can see from the NSV table that the data is in fact changing.
BTW, deadbanding is set to zero so logging should occur at every change.
3. Editing the properties of a NSV will cause that variable to be deleted from the DSM and will have to be redeployed.
4. Historical charts do not update correctly, data points are not connected until you click the mouse on the chart which forces a refresh (this problem was reported back in 2009 and I even
had a net meeting with NI staff where this was mentioned and unbelievably this is still not fixed)
http://forums.ni.com/t5/Real-Time-Measurement-and/Distributed-System-Manager-Historical-Trend/m-p/99...
Message 19 of 27
(12,776 Views)
Switching the radio button style does not retain the enum values
Details.
Message 20 of 27
(12,756 Views)
