Add XControl Properties in LV2010 is not working correctly
Could someone verify this, on my end only the properties folder is created without any templates vi's inside.
Am I doing something wrong?  It seems to work in LV2009
(4,080 Views)
I discovered that if I place a dummy vi inside the property folder that was created and then drag the dummy vi out adjacent to the ability vi's then this kick starts the property
'wizard' and creates a proper template vi and also changes the tree icon adding the small properties wrench in the lower right hand corner.
(4,071 Views)
This is a bug I found too.  It's filed as CAR 277226.
Another work around is to Save All on the project.
-- Mike
(3,961 Views)
