BreakPoint
Monthly Bugs (March 2006)
This is the continuation of the February 2006 monthly bug thread.
Rules:
  1. Each post here should only contain a brief description of a bug, together with a link to the thread where it is being discussed.
  2. One post/bug!
  3. One bug/post!
  4. No discussion of bugs. All discussions of a bug must take place in the original linked thread.
  5. No poofters.
  6. There is no rule 6!
___________________
Try to take over the world!
Message 1 of 25
(10,448 Views)
Constructs that use use a enum constant inside a case structure that feeds two sinks can cause the "constant" value to change at run-time.
See this thread on the LAVA forums for discusions and an example.
http://forums.lavausergroup.org/index.php?showtopic=2718&hl=
This bug has been reported to and confirmed by NI.
Ben
Message 2 of 25
(10,385 Views)
When using "Build All" in the porject explorer, it reports that it has built one more build than it should have (see attahched screen shot).
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
Message 3 of 25
(10,372 Views)
Work around is to drag them off the tab control etc first.
More info in this thread.
http://forums.ni.com/ni/board/message?board.id=170&message.id=171114&a#M171114
This bug has been reported and confirmed.
Thank you,
Ben
Message 4 of 25
(10,352 Views)
When building an installer, it isn't created in the folder you specify, but rather a new subfolder called "Volume"
Message 5 of 25
(10,322 Views)
The Examaple Finder may show up in a different language.
http://forums.ni.com/ni/board/message?board.id=170&message.id=172375
NI confirmed and has created a bug report.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
Message 6 of 25
(10,293 Views)
8.0.1 - icons on the "Getting Started" page have gone odd...
Message 7 of 25
(10,286 Views)
Deselecting "Support all lanuages" in the "Run-Time Languages" section of the app builder disables the "Supported Languages" list - should enable it so you can select the languages you want included.
Message 8 of 25
(10,287 Views)
When building multiple items from the Project Explorer, they are built in the order you select them (eg: ctrl-click each item and then right click and select "Build").  I would have preferred it if the app was biult first, and then the installer - it's possible that someone will do a build all and the installer is built before the app, therefore the install will be the previous version of the app, not the current one...
Message 9 of 25
(10,288 Views)
Crelf, I see that you're following rules 2 and 3, but please have a look at 1 and 4. Not following 1 could lead to a problem with 4. Since, unlike LAVA, this site does not have a board for this yet, it's important to follow these to keep things manageable.
___________________
Message 10 of 25
(10,281 Views)
