Rules:
Constructs that use use a enum constant inside a case structure that feeds two sinks can cause the "constant" value to change at run-time.
See this thread on the LAVA forums for discusions and an example.
http://forums.lavausergroup.org/index.php?showtopic=2718&hl=
Work around is to drag them off the tab control etc first.
More info in this thread.
http://forums.ni.com/ni/board/message?board.id=170&message.id=171114&a#M171114
This bug has been reported and confirmed.
Thank you,
Ben
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
