annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
LabVIEW Minutiae (that may bite you someday)
In this thread Sunflower brings one of the "Bite you" scenarios regarding setting an AE as re-entrant and getting away with it... for now.
Ben
0 Compliments
Message 41 sur 139
15 952 Visites
Casting an int to an Enum (strict).
Who thought it would be so tricky?  Turns out that although I had expected each of the last 4 methods to be functionally equvellent I was wrong.
I guess you really do learn something new every day.
"Should be" isn't "Is" -Jay
Message 42 sur 139
15 894 Visites
Make that constant into a U16 and Bob will be your uncle.
Jim
Message 43 sur 139
15 888 Visites
This NI document explains typecasting an integer into an enum.
Jim
Message 44 sur 139
15 878 Visites
Just when I thought I knew something about LabVIEW!
Thanks Jim!  I wondered WHY- now I know.
0 Compliments
Message 45 sur 139
15 868 Visites
Jeff, you'd might like this too.
Coerce to Type
0 Compliments
Message 46 sur 139
15 854 Visites
Here is one that I also consider bad programming practice.
Default Enums
Setting a typedef enum as Use Default If Unwired always returns the FIRST (lowest number) in the enum. If you right click and create a constant, you will get whichever state was set to Make Current Value Default. This may be different from what the output is when left unwired. The default state is not shown and you have to look at the typedef to find out which will be the output.
Related - if someone rearranges the typedef enum (moves some other text to the first element) then the output of the unwired terminal changes. The state when you create a constant does not.
I think I would prefer a "Create Constant in Unwired Cases" option to use here.
     Rob
Message 47 sur 139
15 840 Visites
You have a value changed event for a combo box with Allow Undefined Strings deselected. You try to enter an invalid string into the combo box the system beeps an error at you and the control is not updated. As soon as you click somewhere else on the FP but the value changed event fires anyway. If you press escape prior to clicking away from the control the event is not fired.
Bug or intended behavior?
See this thread for more info.
LabVIEW 2012
0 Compliments
Message 48 sur 139
15 759 Visites
Grr... It is early and I ran out of time to edit. The link points to the right thread but the wrong post. Just scroll up and see the first post. Anyway...
LabVIEW 2012
0 Compliments
Message 49 sur 139
15 746 Visites
When working with the 3D Graph in the 3D Picture, I got bit.
A is not equal to B
Since I cut-n-pasted from an example I ASSumed that the wire was run behind the structure and worked with the value from "A" right up until I tested it.
Please note the tiny arrows indicating an Input AND an Output.
Can anyone else recall seeing another one these anywhere else?
Ben
Message 50 sur 139
15 680 Visites
